Heatsink and exhaust pipeline
LiberoItalia
Typ Libera: Libero E12 FA Deluxe
Příspěvek od LiberoItalia »
Dear All,
I'm Alessandro, I live in Italy and I'm restoring my 1995 Libero E12.
I read several topics of your nice forum but I couldn't find any answer about my problems.
Briefly:
1. Heat sink. In the engine compartment, the heat sinks are completed destroyed by rust. No more spare parts are available in Italy. Do you know where I can find some, even if not the original ones :idea: ?
2: Exhaust pipeline (with lambda sensor). It has some cracks and should be changed. In Italy it's impossible to find a new or used one, on JP car parts websites I got the same reply. How can I solve the problem?
Thanks in advance for any help
kraxna
Re: Heatsink and exhaust pipeline
Příspěvek od kraxna »
You need to make it by yourself, there are no available new original/nooriginal parts like this.
Zpomal a užij si to. :)
Libero is entering a pure veteran life - most components need to be hand-made. The only spare parts available are used/refurbished. It is possible to get some spare parts new, but not those most used.
I am not sure what you mean by the heat sink in engine compartement - for exhaust? On the exhaus manifold there is only this "U" pipe with lambda, then elastic element, catalytic converter and exhaust silencer.
theberlin
Příspěvek od theberlin »
Gerade bei #eBayKleinanzeigen gefunden. Wie findest du das?
https://www.ebay-kleinanzeigen.de/s-anz ... pp_android
